12-12-2013, 07:10 PM | #1 |
Rep 107
New 3" Intake and 3" Charge Pipe
I could not find an intake or charge pipe that i felt was right so i designed my own! Let me know what you think!
Intake is all 3" till the connection and has two 3" K&N Filters, powder coated wrinkle black. Charge pipe is all 3" with Tial BOV, also powder coated wrinkle black. I would be willing to offer these products to anyone interested! |
12-12-2013, 07:39 PM | #3 |
Rep 70
Awesome initiative mate
Put out some dyno figures on the difference it has made (albeit negligible) but at least instill faith in people that it works and the overall impact is positive. |
12-12-2013, 08:19 PM | #4 |
Rep 107
Although it may look similar to the Injen ones to you, they are actually very different. Injen uses 2.25" tubing and merges it late in the pipe to 3". If you look at mine they are 3" all the way to the point of connection on the plastic tubing. Also, their front pipe sits futher back than the rear pipe, mine are vice versa which does not change the performance at all, but allows you to not have to relocate the power steering reservoir like the Injens.
12-12-2013, 08:23 PM | #5 |
Rep 107
I will try and get some numbers. I had the BMS intakes on before i designed these and i can tell you that i noticed a HUGE difference in the two. Mine are extremely responsive and allows the turbos to spool much quicker and easier. I knew i would notice a differnence in the two, but it was a huge difference.
12-12-2013, 09:42 PM | #7 |
Rep 151
You may have increased the intake piping that you built but it's still going into the rest of the intake tubing to the turbo that is still stock size. I wouldn't think there would be any gains over changing the size of this short piece of intake. Looks good though!
12-12-2013, 09:53 PM | #8 |
Rep 107
That may be your initial thought, however, when it comes to the filter you are breathing though a 3" opening in the filter vs. a 2.25" opening in the filter. Also the larger diameter and length of the piping allows faster spool and less lag.
12-12-2013, 10:12 PM | #9 |
Would rather be driving.
12
Rep 175
Show before and after of intake gains (versus stock and BMS) and you might have some customers!
135i JB4 w/ BMS Flash
12-12-2013, 10:24 PM | #10 |
Rep 107
12-13-2013, 09:34 AM | #12 | |
Just one more taste...
566
Rep 2,011
My Build Thread: Jet Black 6MT 128i with MSport
12-13-2013, 01:17 PM | #13 |
Rep 219
He already stated it was 3" tubing and cones. And there could be a chance that it isnt placebo since terry stated his intake works even though it draws in hotter air because there is more of it. So theoretically, 3" vs 2.25" is even more air. The question would really be if a solid 3" intake is indeed different at all since the dual 3" merges into a single 3" just like the dual 2.25" merges into a 3". I would think dual 2.25" should still supply as much as the 3" pipe it merges into can handle. Anyone know the stock charge pipe diameter?
12-13-2013, 03:43 PM | #14 | |
566
Rep 2,011
If you put a straw in a drink and sucked at a specific vacuum, you would get a measurable volume in over time. Now put a funnel on the end of that straw, but keep the diameter of the straw the same and suck in at the same rate. Do you get more fluid in? The fact that you aren't increasing the smallest ID of the tubing just means you can't pull in any more air than before, no matter the size of the filter you put on.
12-13-2013, 07:25 PM | #15 |
Rep 107
There will always be a bottleneck at the 2.25" plastic piping. Every kit will have that problem, however, it's a matter of making a intake kit that has the best breath ability before that 2.25" with the largest diameter and largest filter and coldest air, and I have done that with this intake.
12-13-2013, 07:30 PM | #16 | |
Rep 107
Put a mesh filter over the straw and suck. Then put a mesh filter over the funnel and suck. You will be able to suck through the one with the funnel MUCH easier since where the mesh is has more surface area to breath through. It's all about the size of the opening in the filter not necessarily the diameter of the tubing. The full 3" on mine however is more beneficial than 2.25. Last edited by Kämpä; 12-13-2013 at 07:36 PM.. |
12-13-2013, 08:09 PM | #17 | |
566
Rep 2,011
12-13-2013, 08:14 PM | #18 |
Rep 107
My background is in building 1000+whp E46 M3s and Supras. I do know a thing or two about designing and fabricating. I will try and get some numbers!
12-13-2013, 08:20 PM | #19 |
Rep 219
Id love to see some numbers! Im all for better parts, but we could theorize for days until we see air flow charts and dynos. Because without something to ground the theory on, its really hard to wrap your head around definately!
12-14-2013, 07:03 PM | #21 |
Aired Out
158
Rep 366
How much? I love the looks!
Past BMWs
2010 E92 M3 - Track Build 2009 135i - FBO, Caged and Bagged 1980 E21 320i - Beauty! 2005 E46 M3 - Bagged 2003 E46 M3 - Track Build |
12-14-2013, 07:17 PM | #22 | |
Rep 16
theoretically it is a superior design. As science would suggest. Plus it looks better. Id buy it. Looks like less kinks than injen (less friction and imposed drag), less heatsoak than BMS. Would like to see numbers! Plus I would think you'd get more responsiveness due to how air flow works (bernoulli's principle as shown above) maybe not a large HP gain, but faster spools due to a larger volume of air being pulled through. shit above all else.. I support a member trying to help out the community with designs.
Semper Fi.
