01-10-2014, 10:41 AM | #1 |
Rep 996
ECS 2-Piece Rotors???
Does anyone have experience with ECS 2-piece rotors. The price seems reasonable and they looked good. I am interested for serious track this season.
http://www.ecstuning.com/BMW-E90-M3-...ors/ES2712810/ |
01-10-2014, 10:51 AM | #2 |
Rep 12,317
Really good looking rotors. Haven't seen these before. Do you already have pads?
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
01-10-2014, 11:07 AM | #3 |
Mr. Nice Says Hello
638
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
it is interesting, i might have to grab a set
01-10-2014, 11:08 AM | #4 |
Rep 996
01-10-2014, 11:54 AM | #5 |
Stop the hate, get a V8
3853
Rep 8,625
I too have questions:
1. How do the cooling veins compare to the stock ones? 2. Do the cooling veins line up correctly with the slots/holes? 3. Are the holes drilled or cast? 4. Why would I buy these as opposed to a stock rotor? (other than the miniscule unsprung weight savings)
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
01-10-2014, 02:11 PM | #6 |
Rep 1,789
How much are the replacement rings?
For comparison, the 2 piece rotors from performance friction are 18lbs, a 4 pound saving per corner. I think they look cool and should do fine for regular driving, but for extended track sessions I'd be more comfortable with stock. Now these might be great, just my impression of them. If the company that sourced the blanks was known, I'd probably be more likely to purchase these over stock. |
01-10-2014, 02:15 PM | #7 | |
Rep 12,317
Current:
01-10-2014, 02:49 PM | #9 | |
Rep 996
http://www.ecstuning.com/BMW-E90-M3-...ors/ES2712816/ |
01-10-2014, 05:28 PM | #10 | |
Rep 12,317
Current:
01-11-2014, 05:42 AM | #11 |
Rep 996
01-23-2014, 10:05 AM | #12 |
3853
Rep 8,625
Curious why ECS hasn't chimed in to answer some questions we have...
01-24-2014, 09:39 AM | #14 |
Rep 996
I am on the edge for buying these but the price difference on their website between ECS Rotors and OEM is huge, mostly the rears. Roughly $100 dollar difference for the fronts and $300 for the rears. ECS if you could chime in?
01-24-2014, 09:47 AM | #15 | |
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
Not sure with the heavier ///M, but it's weird they haven't come in here yet
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
01-24-2014, 11:16 AM | #16 |
Rep 996
01-27-2014, 03:35 PM | #17 | ||||
New Lifetime Replacement Policy
821
Rep 11,738
2 - There is no “correct” here. Our research has shown that the direction/orientation of the slot and/or cross drill pattern is not a significant factor to its performance or function. More important is the spacing of the pattern to provide adequate coverage of the rotor surface, as well as the profile of the slots and holes to reduce stress risers on the surface of the rotor. The holes promote cooling by increasing the surface area of the rotor exposed to cooling air, allowing cross flow, as well as allowing additional cool air flow into the vein structure. The slots are more effective at gas, water, and debris venting than the holes, and they continually wipe the surface of the pads to reduce the potential for glazing. These functions can happen regardless of vane/hole orientation. Our pattern has been developed to work with the internal vein structure without compromising the vein integrity by drilling into a vane. The pattern is catered to each rotor blank we use and since our rotors are directionally veined, the vein pattern limits the fredom we have in our cross drill pattern. For directional rotors, the orientation of the veins is critical to proper rotor cooling, as the vein structure pumps cooling air from the hub to the outside of rotor. 3 - Our cross drilled rotors are drilled, as the description implies. On this topic, there is a great deal of internet conjecture and myth surrounding this question. We have spent a great deal of time researching this topic, and have yet to find any proof that “cast in” rotor holes even exist. Currently, all that exists in the public domain is a few marketing brochures and a magazine article that claim the holes are cast in on the old 993tt rotor rings. No aftermarket companies, including Brembo, are currently advertising or selling rotors with “cast in” holes. We have carefully inspected these fabled 993tt rotor rings, and there are very clear signs of drill marks inside the holes, as well as the typical burrs on the inboard edges one would expect to see from the drilling process. That is not conclusive evidence that the holes weren’t first cast, then finish machined, but if that were the case then any improvement in grain structure would be even further negated. [ECS R&D will continue researching this topic until we know the truth.] Even if there was conclusive proof that rotors from any manufacturer have been cast in, there is still nothing that would indicate a cast hole would offer a favorable, or lasting, difference in grain structure, or improve the residual stresses around the holes. Our cross drilled rotors are stress relief heat treated to reduce residual stresses remaining from the casting and machining processes. 4 - Other than weight savings. The construction of the rotor (FC-30 iron ring with 6061-T6 aluminum hat, proper veins , etc) provides increased cooling capabilities. Replacement rotors cost is going provided savings over the original cost. And have you looked at them? They look amazing! We offer a slightly different take on replacement rings, full rotors at a discounted cost. Currently they are listed at -Front $624.95* -Rear $674.95* I don't foresee a price change on these in the future, but as always prices are subject to change. Quote:
-James Last edited by ECSTuning; 01-27-2014 at 04:27 PM.. |
01-27-2014, 03:45 PM | #18 | |
Rep 1,159
Thanks, Sandeep
M3.E90 JZB Coded.GTSDCT.BomizValved.TurnerTestPipes.ResDelete .EurochargedTune.AAFilter.HRER40s
01-27-2014, 04:19 PM | #20 | |
821
Rep 11,738
I can tell your also looking for deeper information, HERE is a link to an older post with some metallurgy information that is relevant to these rotors, as well as manufacturing information. For sake of openness the post linked is from THIS thread which was started by an upset customer. -James |
02-11-2014, 08:19 AM | #21 | |
Rep 12,317
Current:
02-11-2014, 09:48 AM | #22 | |
Rep 3,675
