01-21-2014, 03:48 AM | #1 |
Scythe-Meister
90
Rep 1,053
Rusty PFC 08
So, just want to see if anyone else had this problem. No harsh chemicals were used, in fact, acid would dissolve rust - just in case anyone asks.
01-21-2014, 11:04 AM | #3 |
Scythe-Meister
90
Rep 1,053
I don't but I do drive around quite a lot and the UK has the highest road salt usage per mile/km of road. Still, PFC do claim to have durable corrosion resistance for their pads based on their marketing material.
While some might say it's just cosmetic, I have found that the rust particles accumulates and hinders the proper release of the pads within the caliper when I release the brake pedal - which doesn't help especially for track use. |
01-22-2014, 12:30 PM | #5 | |
Scythe-Meister
90
Rep 1,053
01-22-2014, 04:42 PM | #7 |
Rep 2,792
It's probably from road salt if you drove on them in the winter. The backing plate is probably just mild steel and when exposed to salty water, it will corrode fast.
The way I see it, you have two options: 1) Bitch to PFC and hope that gets you somewhere (doubtful). 2) Sand them (or have them blasted) and shoot a coat of high temp paint on them, put them back on, and go on with your life. I am still confused how the rust on the pads is causing the calipers to bind?
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
01-22-2014, 06:36 PM | #8 |
Scythe-Meister
90
Rep 1,053
PFC have indeed agreed on a replacement set.
No doubt winter salt has played a role, but if you look at the marketing claims by PFC regarding how corrosion resistant their pads are, this is something that shouldn't happen, especially given that I wash the car regularly and thoroughly during winter. Rust accumulated around the pad ears (both on the pad ears and the caliper), which hindered sliding action of the caliper; I experienced sticking calipers as a result. One would have to constantly sand and apply copper slip. |
01-23-2014, 08:37 PM | #9 | |
Rep 2,792
Congrats on the replacement. I am still doubting that rust on the pad ears could hinder the caliper movement. I would check the slide pins to make sure that they move freely. Have you inspected the piston boot to make sure nothing has damaged the piston?
01-24-2014, 01:55 AM | #10 | ||
Scythe-Meister
90
Rep 1,053
