02-02-2014, 12:17 PM | #1 |
Rep 353
Brake rotor size
Anyone know the size of the brake rotors? It's one of the last few pieces of info we don't have. I'm guessing 14.6" for the front standard brakes, and 15.6" for the CC brakes. I don't see it anywhere.
02-02-2014, 01:48 PM | #2 |
Rep 3,452
I'm not sure they've been released, as I've looked for the specs myself. does anyone know the specs of the e9x M3 brakes and the new F30 M performance brakes? it looks like the standard brakes use the same calipers as the F30 M brakes, but has bigger rotors (and I'm sure the rotors are bigger than the outgoing M3 rotors... My guess is 365-370 mm up front).
02-02-2014, 02:14 PM | #3 | |
Law Enforcer
25182
Rep 22,303
02-02-2014, 02:29 PM | #4 |
Obsessed with braking
39
Rep 82
Drives: 2015 BMW M3
F80 M3 Brake Disc Diameter
Front discs are 380mm. Rear are 370mm.
02-02-2014, 02:32 PM | #5 |
Rep 3,452
02-02-2014, 02:41 PM | #6 |
Rep 10,407
Although it is not entirely clear if they are speaking specifically about the M3/4 front CSiC brake rotor, a size of 410 mm is quoted for the front rotor, that is a whopping 16.1".
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
02-02-2014, 04:12 PM | #8 | |
Rep 353
02-02-2014, 04:25 PM | #9 | |
Law Enforcer
25182
Rep 22,303
02-02-2014, 04:56 PM | #11 |
39
Rep 82
Drives: 2015 BMW M3
1) Can we stop using inches? No one, not even the American automakers, use the English system anymore (except for wheel diameters). Metric is the dominant system of measurement worldwide.
2) A 380mm disc will fit in an 18" wheel. You just need a compact caliper to do it. |
AndrewC198910932.50 |
02-02-2014, 04:58 PM | #12 | |
39
Rep 82
Drives: 2015 BMW M3
02-02-2014, 05:21 PM | #13 | ||
Rep 2,633
02-02-2014, 05:29 PM | #15 |
Rep 1,131
02-02-2014, 05:30 PM | #16 |
Rep 1,131
02-02-2014, 05:32 PM | #17 |
Law Enforcer
25182
Rep 22,303
That's just it. No need for that! There are already kits in red, orange and yellow available alongside the blue.
02-02-2014, 07:37 PM | #18 | |
Rep 20,742
Drives: 2021 911 turbo
They mention 20kg total saving, which is the weight saving on the M5. I believe the total weight saving on the F8X is around 6-7kg... The rotors on the F8X could however still be the same size as on the F1X. |
02-02-2014, 07:47 PM | #19 | |
Rep 7,037
02-03-2014, 06:11 AM | #20 | |
Rep 5,110
The CCB F1x M brakes are 410mm https://m-power.com/_open/b/varlink2...d=2769&lang=en It is correct that CCB requires 20" wheels |
02-04-2014, 06:02 PM | #21 |
Rep 10,407
Bummer, still no form answer on the sizes of either cast iron nor CSiC. Floridagator: Can you provide your source?
02-05-2014, 12:52 PM | #22 | |
Rep 5,110
Steel brakes: 380mm front / 370mm rear CCB: 400mm front / 380mm rear CCB requires 19" wheels according to the BMW configurators that are online at the moment. Last edited by Boss330; 02-05-2014 at 01:48 PM.. |
