02-08-2014, 08:06 AM | #1 |
Rep 2,602
Issue with EDC
I recently got the EDC malfunction error code on my car, a 2008 sedan. Because I had a mechanic working on the front right strut, and because he wasnt able to initially properly secure the collar for the Ground Control sleeve kit, I drove it home a short distance and got the malfunction code.
Because of all of this, I was under the impression it was an issue with the front strut, and wound up getting a set of used struts. I then replace the "damaged" strut, but this didnt resolve the problem. I then processed to plug in the rears to see if one of them was compromised, and the light shut off for about 5 miles, then popped back on. Out of ideas at this point. Any coders out there or anyone have experience with this? I just want to find out what the issue is and resolve it.
02-08-2014, 08:34 AM | #2 |
Grown Azz Man
430
Rep 3,021
EDC module comes to mind. You could unplugged the battery and see if the adaptations and the module will reset...........Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
02-08-2014, 09:27 AM | #3 |
Rep 2,602
Yeah I was told that. Guess I'll try first. Even if I went with KW, I still have to have the module working dont I?
02-08-2014, 09:37 AM | #4 |
Rep 2,602
Found this module, not sure it fits. They should be interchangeable.
02-08-2014, 12:13 PM | #5 |
Rep 834
Stop replacing parts, check all plugs on each strut and make sure each are all the way plugged in and correctly installed, many people had that problem and all it was a loose connection
02-08-2014, 12:35 PM | #6 |
Rep 2,602
02-08-2014, 12:43 PM | #7 | |
BimmerPost Supporting Vendor
8312
Rep 18,880
You need to scan for codes and see what the problem is before working on a solution.
02-08-2014, 01:16 PM | #8 | |
Rep 2,602
02-08-2014, 01:21 PM | #9 |
8312
Rep 18,880
Great! Please follow up on what you find out so we can help.
02-15-2014, 06:30 PM | #10 |
Rep 2,602
Motorcepts showed my the module. It had water damage, likely from small imperfections in the Sonic trunk that I installed. Either that or the drain tube that runs out of the moonroof that goes right over it. Just ordered a replacement.
02-15-2014, 08:21 PM | #11 |
8312
Rep 18,880
That sucks, but thanks for taking the time to follow up. EDC systems are typically problem-free.
02-16-2014, 12:37 PM | #12 |
Rep 2,602
Yes, was very perplexed. But it makes sense, since the drain tube and the tail light are close by.
