02-26-2014, 04:33 PM | #1 |
Rep 132
New X5 Owner Question
My X5 is off in the garage.
The Hazard button on the center dash and the Button under it with the circle around the car stay semi illuminated when the car is off, is this normal?? If I leave the keys in the car unlocked or if I lock it these two lights can be seen on. |
02-26-2014, 04:59 PM | #4 | |
Rep 260
Drives: F30 2016 340i xDrive Sport
MEDITERRANEAN BLUE METALLIC W/ BLACK NEVADA LEATHER & OYSTER HIGHLIGHT | SPORT PACKAGE | SPORT AUTOMATIC | HARMAN KARDON | PREMIUM PACKAGE | TECHNOLOGY PACKAGE | DRIVER ASSISTANCE PACKAGE | LIGHTING PACKAGE | CARBON FIBER M SPORT LIP SPOILER | BLACK KIDNEY GRILLES | BADGES OFF
02-26-2014, 06:19 PM | #6 |
Rep 54
02-26-2014, 06:40 PM | #7 |
Rep 132
02-26-2014, 06:42 PM | #8 |
Rep 132
Another X5 question.
So I leave the keys in the car when its in my garage, I press the Start/Stop button and turn off the engine, but it seems that to turn off the iDrive/Radio I need to press the Start/Stop button again or lock the car from the outside? Is this correct or is there some setting that pressing the Stop button turns off the car and iDrive/Radio?? Thanks |
02-26-2014, 06:47 PM | #9 | |
Rep 260
As a separate note, do not leave your key in the car in the garage. It will eventually drain your battery and they won't cover it under warranty - they're first question would be do you leave your key in the car.
02-26-2014, 08:45 PM | #11 | |
Rep 132
How is keeping the key in the ace while it's off going to drain the battery? |
02-26-2014, 10:52 PM | #12 | |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
02-27-2014, 08:22 AM | #13 |
Rep 132
Ok, thanks
Another question. Can I remove that stupid Phone Dock in the arm rest compartment? I'm not going to use it and it takes up a lot of useful space. Can It be unscrewed and removed?? Thanks |
02-27-2014, 01:18 PM | #14 |
Rep 260
Car has comfort access and the car knows the key is in the car so certain systems will toggle between on and off.
02-27-2014, 01:18 PM | #15 |
Rep 260
No, it cannot be removed, it is part of the BMW Apps/Smartphone integration, comes from the factory and might even be standard now in the vehicle.
02-27-2014, 03:25 PM | #17 | |
Rep 161
http://f15.bimmerpost.com/forums/sho...d.php?t=927835 and also hre : http://x3.xbimmers.com/forums/showthread.php?t=836827 this tutorial is for X3 but it should be similar for F15 with the correct parts. |
