BMW X5 and X6 Forum 2014-Current
      03-07-2014, 08:43 AM   #1
polly
polly's Avatar
South Africa
123
Drives: 2010 e90 m3
Rear noise pls help
Hi everyone. I am hearing a "thump " sound coming somewhere from the rear. It happens mostly when I go over a bump or on my driveway. It is really irritating. Has a similar sound like unlocking the door. I don't have a single thing in the boot. It seems like the sound is coming from the left hand side of the boot area. Any one experience this or can advise were I can look.
Thanks in advance for any help.
      03-08-2014, 06:49 AM   #2
polly
polly's Avatar
South Africa
123
Drives: 2010 e90 m3
Hi everyone
I managed to find the rattle. It's coming from the plastic just behind the rear window wiper in the trunk. It seems as if that plastic panel is hitting against the rear glass. Does anyone have a step by step guide on how I should remove this panel. I thought if I could remove it I can maybe insulate it with some foam and re fit.
Regards
      03-08-2014, 07:05 AM   #3
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
I sometimes get a sort of tin can sound sometimes when making turns. Going to take it in for a blown fuse and have them look into the sound too. It's pretty consistent and I don't think we have anything in the car that would make that sound, and it's only when turning, not bumps or anything else.
      03-08-2014, 07:16 AM   #4
Baunton
Baunton's Avatar
England
320
Drives: X5 45e 2021
Originally Posted by polly View Post
Hi everyone
Regards
Have you told the dealer? Get them to fix it...You paid enough for your pride and joy!
      03-08-2014, 07:57 AM   #5
polly
polly's Avatar
South Africa
123
Drives: 2010 e90 m3
I'm taking it in next week. Just thought if its a small job I could have tackled it myself.
      03-08-2014, 01:24 PM   #6
mikikuki7
mikikuki7's Avatar
Drives: Searching for X6M or M8
I would've done it myself. BMW service employees are worthless... Only reason why I take my BMWs are for big issues and regular maintenance.. I wouldn't let them touch any interior parts unless it was major. 😡
      03-09-2014, 10:02 AM   #7
mattbar1
Drives: 2014 X5 M Sport 50i
I agree. I picked up my car on Wednesday. The three problems that I have found so far were all caused by the dealership during PDI. They are supposed to be checking for problems, but they are causing problems. Really upsetting.
They scratched the door. Sliced the manuals book pleather cover with a razor. And broke the plastic cover that covers the keyhole on the driver door. This is what I am aware of so far...
      03-31-2014, 03:42 PM   #8
Baboum68
France
Drives: X5 G05
did you fix it eventually? I have a plastic noise coming from the back also. I can't identify the origin of it...
      04-01-2014, 08:25 AM   #9
Shaw
Shaw's Avatar
Drives: 2016 X5 35d | 2019 X3 30i
not sure if similar...but I had the exact same problem with my X3...noise coming from the trunk every time passing a bump or uneven surfaces...
after doing so many back & forth to the dealership trying to find the cause, it was the lock latch...once they replaced it, the noise was gone...
someone had to sit in the trunk while doing a test drive to find the source of the noise...
Although, I remember the sound was coming back right around the time that I was selling it...
      04-01-2014, 08:52 AM   #10
sirajkas
Drives: BMW X5 2014
I have the same problem.. Noise coming from the rear.. What was the fix for this?
      04-04-2014, 07:00 PM   #11
sirajkas
Drives: BMW X5 2014
This is happening a lot more now and it's annoying. Anyone else having this issue? I'm going to take it to dealership tomorrow.
      04-07-2014, 01:48 PM   #12
Baboum68
France
Drives: X5 G05
did you take it to the dealer?
      04-07-2014, 02:11 PM   #13
mikikuki7
mikikuki7's Avatar
It's the space saver plastic... I removed it and put cloth tape lol and now it's back to the way I like it... Quiet!!!
      04-07-2014, 02:23 PM   #14
sirajkas
Drives: BMW X5 2014
Yes, obviously the noise wasn't too obvious when the foreman came for a test drive with me. He said everything is normal. Sometimes it is loud and sometimes you can barely hear it.
      04-07-2014, 03:36 PM   #15
kip1
Drives: X5M50d
What is the space saver plastic?
      04-07-2014, 04:19 PM   #16
mikikuki7
mikikuki7's Avatar
Look... There and my finger holding the cloth tape... I put it on the lower pillars and I love my X5... Once again!
      04-07-2014, 06:25 PM   #17
sirajkas
Drives: BMW X5 2014
Do I need to remove anything?
      04-07-2014, 06:31 PM   #18
mikikuki7
mikikuki7's Avatar
Well... If you Wanna Fix the noise yes... It's easy...
      04-08-2014, 08:59 AM   #19
kip1
Drives: X5M50d
Thanks
      04-10-2014, 03:44 PM   #20
Baboum68
France
Drives: X5 G05
I went to my dealer and he adjusted the hook of the trunk lock. It is now much better but not perfect. It seems like the trunk lid is not closing tight enough which is causing the lid to move and make noise. Because it is not 100% fixed, I need to come back next week. They will replace the whole lock.
      04-11-2014, 09:23 AM   #21
oskee64
oskee64's Avatar
Drives: '14 X5M Sp/'06 M3/DD:Inf QX4
I have the same issues everytime i runover certain bumps. It's on my right rear. I will investigate this weekend. MTF.....
      04-11-2014, 10:46 AM   #22
Caligts24
Drives: 2017 BMW X1 M-Sport
My F15 has a similar noise coming from the rear and my wife has threatened to kill me if I dont get it fixed this weekend. I'm going to sit back there while she drives around and I'll get to the bottom of this. Sounds like it could possibly be a few things.
xbimmers
