03-09-2014, 06:53 PM | #1 |
Rep 82
I just got my berk race axle back installed and it sounds sick. Until I heard rattling. No, not from the drone. I saw that the pipe is laying on the sway bar brace. Got this from a member here and the condition is pretty much brand new.
Been searching around and can't really find a solid solution on what to do. In the picture, if you follow the pipe to the front where the flange is; you can see the silver brace where it's rubbing against. Any ideas? Put some exhaust wrap around it? http://i58.tinypic.com/14e2v0k.jpg |
03-09-2014, 07:10 PM | #2 |
Rep 760
Drives: E82 135i & F80 M3
You might just need new exhaust rubber mounting bushings.
Make sure all three are properly mounted and fully inserted as well. Berk Exhausts are very well made and I haven't heard of any fitment issues over the years. |
03-09-2014, 07:18 PM | #3 |
Rep 82
Hmm.. The hanger rubber hanger bushings are fine. They're actually pretty much new. Car only has 4000 miles on it... Bought it last month lol
I could try playing around with it to see if it adjusts around a bit. |
03-11-2014, 11:13 AM | #4 |
Rep 952
I take it this is a vert? Coupes don't have that brace, so it's not a problem.. I think your only options would be to bend the brace, put a dent in the pipe, wrap the pipe, or ... I dunno, that's pretty much it
03-11-2014, 01:10 PM | #6 |
Rep 847
Drives: 2011 135i M Sport
My buddy has a Vert and it what we did was got a clamp and clamped the Exhaust to the brace and it stopped making the clattering noise
BMW Performance Kidney Grille, CF Lip Spoiler, CF Diffusser, Blackline LCI Tailights, Magnaflow Full Exhaust, BMS Intake, Jb4 w/ E85, Meth Injection, BMS DP, VRSF 5" Intercooler, CP-E Charge Pipe, KW CS Coilover, M3 Subframe Bushings, VMR VB3 Wheels, Stage 2 Fuel Pump, M3 Control Arms, Dinan Camber Plates, Pure Stage 2.
03-11-2014, 01:30 PM | #8 |
Rep 847
Exactly that! It worked and its still on there =]
03-11-2014, 01:32 PM | #9 |
Rep 6,478
Lol I see you’ve encountered that problem, eh?
Space it down a bit with washers, and wrap the bar with exhaust tape. Resonance gone. Under load the exhaust flexes more than you’d think, so spacing it down half an inch likely isn’t going to fix it. It’s not “hard” to fix at all though, just takes a bit of thought. It’s that ‘vert life my friend, get used to it.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
03-11-2014, 07:43 PM | #11 |
Rep 1,051
Don't be afraid to put a small dent in it. Really won't hurt anything. Mark it with a marker, take it off the car, give it a good smack with a standard hammer.
https://dl.dropboxusercontent.com/u/...rannytouch.jpg https://dl.dropboxusercontent.com/u/...annytouch1.jpg https://dl.dropboxusercontent.com/u/...annytouch3.jpg https://dl.dropboxusercontent.com/u/...indpclear1.jpg https://dl.dropboxusercontent.com/u/...indpclear2.jpg https://dl.dropboxusercontent.com/u/...pclearfix2.jpg https://dl.dropboxusercontent.com/u/...pclearfix3.jpg
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
