03-23-2014, 10:53 AM | #1 |
Rep 1,265
Drives: 1973 Jensen Interceptor
Mixed messages on Test pipes and Rasp
I want to get some test pipes and keep the secondary cats and the rest of the exhaust OEM but so far I've seen some conflicting info on the matter regarding rasp as a result.
I cant stand a raspy exhaust. So will the exhaust note get raspy or not with the test pipes? Thanks! |
03-23-2014, 11:11 AM | #2 |
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
Technically, I am sure rasp does increase.
Realistically, chances are most won't really detect the increased rasp. I installed a XPipe with a primary cat delete, but it retained aftermarket secondary cats and resonators. With my OE Muffler, I did not notice any increased rasp during my daily commute. I installed test pipes on another E92 M3 that has an Eisenmann Race. In-cabin, any potential increase in rasp is fairly minimal and pretty much imperceptible. My tolerance of rasp may be different than others though since I also have an E46 M3 with catless headers. The E46 M3s are NOTORIOUS for absurd rasp, so my perception of rasp may be skewed.
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
03-23-2014, 11:19 AM | #3 |
Rep 1,130
It's slightly more raspy. I believe this will occur anytime you remove a resonator/cat? I am very picky but quickly got used to it and it's definitely worth the extra hp.
03-23-2014, 11:29 AM | #4 |
Rainbow Racer
1008
Rep 2,540
it may sound raspy at heavier throttles when the exhaust/muffler is still cold. the raspy essentially quiets to an almost undetectable amount once warmed up.
03-23-2014, 11:50 AM | #5 |
Rep 6,871
If you can't stand raspy exhausts then you absolutely do not want test pipes with the oem rear. Search for some vids as there are plenty and it will give you an idea of the rasp you would get.
03-23-2014, 11:57 AM | #6 | |
Rep 12,318
So in summary, completely depends on muffler. But with completely stock muffler, you'll be fine.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
03-23-2014, 12:49 PM | #8 |
Rep 3,982
Test pipes with the rest of the exhaust OEM will result in more rasp with the rear oem silencer. Its not that bad but it is there, I ran the OEM rear muffler for awhile with my testpipes and yes there was some rasp but mainly when the exhaust was cold. As it got to operating temp it did diminish a tad.
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
03-23-2014, 12:52 PM | #9 |
Rep 496
Xpipe with HFCs and resonators with OEM rear sound refined, high pitched and to me a natural rasp. Sounds close to a CSL only a few tones deeper. If you like CSL sound you will live it. If you hate CSL sound you won't like. To me its a raw engine nouse
03-23-2014, 02:35 PM | #10 |
Rep 10,407
A classic raspy exhaust to me is E46 M3. My test pipes did not increase that particular sound quality.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
03-23-2014, 05:11 PM | #11 |
Rep 1,548
Sorry for stupid question. What does rasp mean? Is it the sound that exhaust produce when you remove the Cats? If yes, how come I did not notice that when I installed BMS DP on my ex-car 335i.
03-23-2014, 08:17 PM | #12 | |
Rep 1,265
When I had my 335i I had a slight rasp with the catless downpipes that was gone when i heat wrapped the downpipes. |
03-23-2014, 10:13 PM | #13 |
Rep 2,806
Drives: '09 E90 M3 - IB
I do sound for a living and did a high-quality before/after sound recording when the test pipes were installed. It is more raspy than stock. The recording shows the difference pretty well on the dyno.
Here's the thread where you can find the video: http://www.m3post.com/forums/showthread.php?t=767814 |
03-23-2014, 10:27 PM | #14 |
Rep 10,407
Then of course you realize that the play back equipment is just as important as the recording equipment/technique...
03-23-2014, 10:33 PM | #15 |
Rep 2,806
Of course, but what helps here regardless of the playback system is that you have a direct side by side comparison recorded from the same source. So even on a limited playback, you can still compare the tones. That rasp will show itself on pretty much any playback setup. It's a very mid-range frequency sound. And most cheap playback systems tend to emphasize the mid-range. They suffer when trying to replicate quality highs and lows. But that's not what we're listening for in this case.
03-23-2014, 10:43 PM | #16 | |
Rep 1,265
03-23-2014, 10:47 PM | #17 | |
Rep 10,407
03-23-2014, 10:50 PM | #18 |
Rep 10,407
I agree, its much less intense than in the video I just posted above but it is the same essential rasp.
03-24-2014, 11:16 AM | #19 |
Bimmer Fanatic
371
Rep 1,662
I had the stock exhaust with an acm mod with test pipes and it was extremely raspy, that same mod without test pipe sounded great. But when I switched to Megan almost all rasp was gone.
03-24-2014, 11:35 AM | #20 |
Rep 602
Dunno if it's raspy...it's rippy =) Here's mine recorded with an external mic I put on the rear license plate with my gopro. Test Pipes + Dinan Rear.
https://www.dropbox.com/s/yozqgkl3x5...tto2ndGear.mp4 https://www.dropbox.com/s/4ffskwd09a...dto3rdGear.mp4
[08 e90 M3. Jet Black/Black. Dinan Rear Exhaust. ACM Test Pipes. ESS Tune. Eibach Pro-Kit + e36 bumpstops. 18x10 Apex Arc-8. AA Air Filter. RPI Scoops. CREE Angel Eyes. OEM Blacklines. Black Reflectors. Gloss Black Grills. Matte Black Gills. ZCP Shift Knob]
03-24-2014, 11:55 AM | #21 |
Rep 1,265
03-24-2014, 05:44 PM | #22 |
Rep 1,201
As others have said, it comes down to what muffler/axle-back you're running if its just test pipes and not a full x-pipe.
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
