03-27-2014, 04:01 PM | #1 |
Rep 18,794
DIY: BMS Stage 1 for N55 F15/F16 X5/X6 sDrive35i/xDrive35i
I have received a few questions on how easy is the installation and removal on the BMS Stage 1 for the F15 N55. So, here is the DIY.
There are 4 pairs of connectors and 4 wires coming out of the 25-pin D-Sub connector. - D-Sub connector: Connected to the module - 4 wires (Black/Brown/Red/Green): Not used (For other application) - Purple / Black wire connector: Not used (For other application) - Blue wire connector: Not used (For other application) - Brown / Black wire connector: For MAP sensor - Rainbow wire connector: For TMAP sensor Now, let's the work begin. Step 1: Remove the airbox, using flat screwdriver to loosen up the hose clamp and Torx T25 for the 6 screws on the airbox. You need to remove the airbox for easy access to the MAP sensor. Step 2: Unplug from the MAP sensor and connect it to the Brown/Black wiring plug pairs from the JB wiring. ** The new BMW plugs are not as easy to take off, you may want to use a flat screwdriver to flip the tab. Step 3: Unplug from TMAP sensor and connect it to the Rainbow wiring plug pairs from the JB Wiring. ** The new BMW plugs are not as easy to take off, you may want to use a flat screwdriver to flip the tab. Step 4: Replace and secure the airbox to its original place. Last step: Reroute the cable to your liking. Do secure the module so it is not dangling in the engine bay by the wire. That's all, enjoy the additional power. Oh, remember, this module is designed for OFF-ROAD use only ** Regular Legal Disclaimer for any aftermarket mods ** Technically, you don't need to remove them for every service as it is not detectable. But, if you have a very anal SA or bringing the car for warranty claim, I suggest you to remove it.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... Last edited by r33_RGSport; 07-20-2017 at 05:47 PM.. |
03-27-2014, 08:42 PM | #5 | |
Rep 18,794
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
03-27-2014, 09:56 PM | #7 | |
Rep 18,794
To clarify their information, JB4 Stage 2 will not work on the X5. Only JB4 Stage 1 for the N55 works on the X5. I have been using it for 3 months.
03-28-2014, 08:28 AM | #8 | |
Rep 147
Which one did you order then? Looks like there's 8 options, none of which say F15. Did you go with the F10 harness type B? Thanks! |
03-28-2014, 01:53 PM | #10 | ||
Rep 18,794
You will need the F10 harness type B. The F30 one just have longer cable. Quote:
late 135, 235, 335, 435, 535, 640, X1 35i, X3 35i, X5 35i. About horses, I can't fit any horse in the X5. But, yea, based on the advertisement, it should add about 50hp and 60tq to the wheels.
03-28-2014, 02:14 PM | #12 | |
Rep 193
Really??? You can't fit horse??? May be small pony??? 50Hp-it is not baaaad, can you feel result??? |
03-28-2014, 03:36 PM | #13 |
Rep 18,794
Djarvik,
Yes, they do. It is the JBD, advertised at 60+ hp and 100+ tq gain.
03-28-2014, 03:39 PM | #14 | |
Rep 18,794
I sure can feel the result. I have been driving in comfort mode without complaining. But, when you put it into a Sport mode, You will forget that you are actually driving a truck.
03-28-2014, 04:46 PM | #16 | |
Rep 18,794
BMS told me that you will need to use 2x JB+, 1 for left MAF and 1 for right MAF. Maybe you can give me some more info on your engine type, it should says on the window sticker. It is either the regular N63 or the N63TU.
03-29-2014, 10:02 AM | #18 |
Rep 18,794
Do you mind send me the picture of your engine and last 7 of VIN?
03-29-2014, 03:43 PM | #20 |
Rep 18,794
That way, the tune for it is N63tu Stage 1.
BMS asking for $599.00 + shipping.
03-30-2014, 07:01 AM | #21 |
Rep 118
I think that it might be helpful to explain what "N55 JB4 State 1" means. I have no idea what those letters and numbers mean. Are they an option that is available from the factory that you are retro-fitting? if so, what option?
thanks,
someguy |
