XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      04-23-2014, 03:09 AM   #1
Tossi
Denmark
9
Drives: F11 20d
BMWhat has anyone tired it?
As the title says, has anyone here tired it? I have tried the Lite version with my LYL Elm327 WIFI dongel and it keeps telling me that the type of car/ecu doesn't support coding over wifi, which seems a bit odd because acording to BMWhat site it should work with cars newer than 2007...
2011 F11 520d
      04-23-2014, 06:50 AM   #2
quiksilverdad
Drives: x1
I use the bluetooth elm327
      04-23-2014, 07:05 AM   #3
Tossi
Denmark
9
Drives: F11 20d
with iphone or andriode? I forgot to wirte that i have only tried with iphone.
2011 F11 520d
      04-23-2014, 08:01 AM   #4
quiksilverdad
Drives: x1
Android. Some things work others dont. Does not read every ecu.
      04-23-2014, 08:04 AM   #5
Tossi
Denmark
9
Drives: F11 20d
will give it a shoot again today with my ipad and see if that works any better
2011 F11 520d
      09-30-2015, 08:11 PM   #6
tuanvo1982
Australia
Drives: BMW X1 xdrive20d 2010
everything is work with E84 except parameter + DPF
      10-01-2015, 11:32 PM   #7
vstolpner
Drives: 2019 F39 X2 m35i
I think iPhone version can only use the WiFi adapter, not Bluetooth. Waiting to convince the wife that it's a worthwhile investment before buying the app :-D
      10-02-2015, 10:10 AM   #8
themishmosh
Drives: BMW X1 xDrive35i
If you have the iPhone, I'd get the official Carly wifi OBDII adapter
      01-14-2016, 01:25 PM   #9
Bill B.
Bill B.'s Avatar
Drives: '18 M2, '13 X135i '15 S1000R
Smile If you are going to buy an official Carly adapter - save 5 bucks
If you are planning to buy any Carly adapter (from ivini-tech or Amazon) use this code for 5 bucks off:
Y49N5K
This code can be entered on www.ivini-tech.de/en in the shopping cart, when making an order for adapters, 5€ will be deducted from the shopping cart value right away.
For users ordering through Amazon UK or US, please contact them first regarding your voucher code before the adapter purchase via trainer@mycarly.com and they will give you a code that works on Amazon.
***** FULL DISCLOSURE ****
As a "Carly Trainer" I do get a kickback which I mostly use to buy adapters. As an aside, they are starting to support BMW bikes as well for any of you that have a beemer, too!
      01-14-2016, 03:32 PM   #10
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Y49N5K
Just tried it and the promo code doesn't work with Amazon.
      01-17-2016, 07:35 AM   #11
Bill B.
Bill B.'s Avatar
They say:
"For users ordering through Amazon UK or US, please contact Carly first with your voucher code before the adapter purchase via trainer@mycarly.com and they will give you a code that works on Amazon."
They have been relatively responsive via that email address, and by that I mean a day or so.
      01-25-2016, 08:20 PM   #12
punchyninja
Drives: BMW X1 x28i 2014
I've used it with iphone and the carly OBS II adpater. Works great, easy to set up and code. I've removed the attention warning, allowed dvd play back on drive, removed seat belt warnings, and added speedo to the center. all easy to do, and it backs up the defaults.
      06-05-2016, 08:31 PM   #13
Mirko
Mirko's Avatar
Drives: E86 Z4M, E90 328i, E84 X1
Is there a trick to get it to work? I can get it to read from the car no issue using either my bluetooth dondle or the cable but I can't get it to write. Regardless of if the car is on or off.
I've not had issues before on my e90 or z4m. I did reach out to them but no response yet.
08 M Coupe • Ceramic Black Fabspeed Headers • MCS 1WNR • Poly FCAB • Stoptech BBK • Vibra-Tech • Epic Tune • Apex EC7 • RPI Scoop • Eventuri • Stromung • Rogue X Pipe • Varis Diffuser • CF E92 GTS Wing • CF Roof
      06-14-2016, 12:40 PM   #14
thestimp
Drives: 22 X3MC MBB - C-17 Globemaster
2022 X3mC  [10.00]
2016 BMW M3  [0.00]
DO you have Gen 1 or Gen 2,
Which car are you trying to code? Series and Chassis code<
So when you hit the check boxes and then code nothing happens? Does it show any errors?
      06-14-2016, 01:16 PM   #15
Mirko
Mirko's Avatar
it is a gen 1 e84, 2012. The software attempted to code the car but in the end it would just say could not code try again.
I did eventually get it to work on my second attempt a few days later. I did nothing differently and it just accepted the coding.
I did email the developer who responded back to me to do a session and send it to them but I didn't end up needing to. maybe they updated something in their program or the car just wanted to behave that day.
thank you for following up! I appreciate it.
      06-15-2016, 09:50 AM   #16
thestimp
2022 X3mC  [10.00]
2016 BMW M3  [0.00]
Make sure if you have a JB4 installed to put it on MAP 0 otherwise they will battle each other. Sometimes it will work other times it will cause your car to jitter because the JB4 auto delete error codes feature will beat the Carly each time.
Otherwise it might just be an issue with your phone crashing while loading the app, that also happens from time to time.
      06-16-2016, 12:52 PM   #17
themishmosh
Thanks for the tip. Have been having the darndest time lately communicating with the car. Seems like the device freezes up with one of the LEDs flashing rapidly and then the app crashing.
      06-21-2016, 09:02 AM   #18
kiloTHREE
Drives: '13 xDrive28i
I recently picked up the Carly (BMWhat) bluetooth adapter v2.
Works great, takes a while to connect.
Make sure you aren't paired with your car at the same time as this will cause headaches.
You don't actually connect to the bluetooth dongle till the app is started, so don't worry if it doesn't connect and pair like a usual bluetooth device.
Be sure to test with the free demo app before purchase just to see if it works.
I also recommend running your car while doing coding, help keep the voltage stable.
Coded out my warning screens and enabled remember last set for auto start/stop.
After coding changes you have to turn off the engine and restart, which means you have to dig back through the menu's and read from the car again, not a pain by any means but takes a few more seconds.
One thing to note, there are a lot of in app purchases required to get full functionality. This is noted on their website, although poorly. So keep in mind for full app, all unlock+dongle your looking at ~160.
Which isn't too bad, I came from AUDI/VW and most diagnostic tools come in around 250 range, but much more full featured.
IIRC:
iDrive settings: $15 (warning screens)
Battery: $15 (swapping battery reset/register)
Advanced Service: $7.50 (advanced service reset)
      06-21-2016, 09:27 AM   #19
vstolpner
What did the advance service include?
      06-21-2016, 09:42 AM   #20
kiloTHREE
Not much frankly, reset service intervals (can do this anyhow via BC button IIRC), and check remaining service life according to their website.
Honestly I haven't dug much into that part yet,just bought everything at once just in case.
      06-24-2016, 11:14 AM   #21
thestimp
2022 X3mC  [10.00]
2016 BMW M3  [0.00]
Advanced service is ,
Brakes
Fluids,
Oil
Engine service interval,
Nothing too crucial me thinks, the better option is the warning screen, battery change reset and DVD in motion options.
They are always adding to their app seems like an update weekly, although I suspect they have moved on to F series.
      06-24-2016, 12:06 PM   #22
kiloTHREE
Brakes
Fluids,
Oil
Can you set the interval or is it only reset?
Would love to set to 5k reminders.
xbimmers
