Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > BMW M6 Forum (F12 / F13)
      04-23-2014, 03:01 PM   #1
mr-karim
mr-karim's Avatar
Drives: F13 M6 (Fully Modded)
Post Dynoed my car at Dynojet (chart)
Dynoed the car at Dynojet, 622whp = 713hp crank (considering 15% loss)
Used +3PSI on 96 octane.
Did 4 pulls, 2 on 4th gear, 2 on 5th gear.
Should receive Vorsteiner parts next week, I will dyno my car again with +2.5 PSI to see the difference.
"The best things in life are free. The second best are very expensive." - Coco Chanel.
      04-23-2014, 03:45 PM   #2
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
nice
      04-23-2014, 04:06 PM   #3
mr-karim
mr-karim's Avatar
Lowered PSI level from 3.0 to 2.5, car feels way faster! I guess 96 octane is not enough for 3PSI, retest next week! Will keep you updated.
      04-23-2014, 04:21 PM   #4
gmd2003
gmd2003's Avatar
354
Drives: 2014 CP M6 and 2006 VT 525 Z4M
What happened on that first run the AFR's went extremely lean and correspondingly the tq and hp dropped off early . There was a ton of variation between the runs too . Did you run the car on the 96 octane and the BMS settings before the dyno ? It appears on the first run the ECU wasn't ready for the extra boost .
      04-23-2014, 04:25 PM   #5
mr-karim
mr-karim's Avatar
I did 2 runs in 4th gear, and 2 runs in 5th; extra $100 but I needed to compare. I wanted to see how 96 octane would do on Dynojet with 3psi over stock. To be honest it feels a lot faster in +2.5 psi.
Retest next week
      04-23-2014, 05:25 PM   #6
turbo8765
Drives: very fast
Do you have the SAE numbers?
      04-23-2014, 05:33 PM   #7
gmd2003
gmd2003's Avatar
354
Retest next week
I would def not run the +3 psi setting again you proved the car was running lean as hell with that 18 AFR at redline , you're lucky you didn't have engine damage . Also if you notice you made the most power on the run with the richest AFR .( this is usually not the case , only when you are running too lean is this true ) . Where is Mike to tell us the 18 AFR is ok lol .
      04-23-2014, 05:35 PM   #8
mr-karim
mr-karim's Avatar
You mean this?
      04-23-2014, 05:38 PM   #9
mr-karim
mr-karim's Avatar
Do you think +0.5 PSI is a big difference?
      04-23-2014, 05:43 PM   #10
gmd2003
gmd2003's Avatar
354
Apparently so based on the dyno results and you yourself said it feels faster at 2.5 . That's because it is ! That must be the limit of adaptation for you're car with the mods you have .
      04-23-2014, 05:46 PM   #11
mr-karim
mr-karim's Avatar
Very curious to see how the car will do next week, 96 octane with +2.5 PSI. I think I will get a bit less HP but way more torque.
      04-23-2014, 06:15 PM   #12
JoeyLeeBMW
JoeyLeeBMW's Avatar
Drives: 2014 BMW ///M6 Alpine White
#BEAST great numbers Karim!
Joey Lee BMW l ///M Power l IG: JoeyLeeBMW
2014 BMW ///M6 Coupe "Competition Package" CLICK: Intro Thread Pictures
l Vorsteiner CA Demo Car l Toyo Tires l Trinity Autosport l Targa Trophy l Shift S3ctor
      04-23-2014, 08:13 PM   #13
mr-karim
mr-karim's Avatar
Thanks man Not as great as your 640whp score, but trying to find the perfect boost level
      04-23-2014, 08:30 PM   #14
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Yeah the torque isn't as high as I would think. I put down 620tq. Torque wins races and feels great . Looking forward to your next dyno
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread:
http://www.6post.com/forums/showthread.php?t=794659
      04-23-2014, 08:31 PM   #15
mr-karim
mr-karim's Avatar
Booking it right now. I changed settings back to 2.5 PSI, and the car feels a lot faster, I'm getting way more torque now. Trying to book for friday, will keep you posted.
      04-23-2014, 08:55 PM   #16
Hunter5179
Hunter5179's Avatar
Nice. Usually when the car is running lean it should pull a code. Have you pulled any codes?
My Thread:
      04-23-2014, 08:59 PM   #17
mr-karim
mr-karim's Avatar
That's all I got from Dynojet
      04-24-2014, 10:42 AM   #18
ice7
ice7's Avatar
371
Drives: ///M's
2014 BMW M5 Comp  [0.00]
2015 BMW X5M  [0.00]
2022 BMW M5 CS  [0.00]
impressive numbers! What numbers were you getting stock?
      04-24-2014, 01:44 PM   #19
mr-karim
mr-karim's Avatar
I don't have stock numbers
      04-24-2014, 02:47 PM   #20
LSM
LSM's Avatar
Drives: 2024 Porsche 911 GTS Cab
Definately...Better at 2.5..Bet you will get even higher numbers
2024 Porsche 911 GTS Cabriolet
      04-24-2014, 02:49 PM   #21
mr-karim
mr-karim's Avatar
Not sure about HP numbers, but torque should be a lot better
      04-24-2014, 02:50 PM   #22
LSM
LSM's Avatar
These SAE corrected numbers? The non corrected numbers are higher than SAE which is what the dyno jet should be corrected to
Tags
bms tune, dyno, f13 m6
6post.com
