05-07-2014, 05:31 AM | #1 |
Rep 2,438
Alignment spec for active steering with M3 control arms
Can anyone please help me out on this I am upgrading control arms to M3 also rsb to M3 my car is equiped with active steering what should be my alignment spec.
Please help any tips? |
05-07-2014, 06:06 AM | #2 |
European Editor
10639
Rep 22,992
Maybe this will help you Rimas...
1M versus M3 stock suspension settings http://www.1addicts.com/forums/showthread.php?t=634707
05-07-2014, 08:06 AM | #3 | |
Rep 2,438
05-07-2014, 05:14 PM | #4 | |
European Editor
10639
Rep 22,992
SZL sensor ?
I think you mean the SZL sensor right ? Its easy to reset. BMW steering wheel sensor re-setting… http://www.1addicts.com/forums/showthread.php?t=504482 Quote: Originally Posted by @DriveHard HOPE YOU READ THIS BEFORE YOU GO BACK.. sit in car, start engine, have steering wheel in straight ahead position without pausing, turn wheel slowly all the way to the left and pause at the end for a second or 2 without pausing, turn all the way to the right and pause at the end for a second or 2 repeat the last 2 steps and end in the straight ahead position. turn off car, wait a minute, restart, and drive away for a few hundred feet. you just calibrated your SZL ( steering wheel sensor to tell dsc if wheel is turned and to what degree) other lights come on by default. Good Luck... Dack
05-08-2014, 04:40 AM | #5 | |
Rep 2,438
