05-08-2014, 12:23 AM | #1 |
Perception is King
131
Rep 1,703
Rear sway bar?
Anyone done a rear sway bar? reason i ask is im at some piont going to have solid sub bushing done and they told me theyll do the sway bar switch for free so i figure cant hurt right, but is it worth the $300-350 for a rear sway bar?
Perception and Reality are Two totally different Things.
05-08-2014, 12:29 PM | #2 |
Rep 1,339
The main cost of putting in a rear sway bar is the labor to drop the sub-frame, so if it were me, I'd do it. I opted out of doing it becasue of the cost and just installed a front sway bar, which is a much easier install.
05-08-2014, 02:18 PM | #3 |
just another M3
514
Rep 1,152
I did my rear sway bar(RD SPORT) for street driving its useless. But if you track and have proper grip on your tires it improves a lot. Or to dial in steering characteristics.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
05-28-2014, 04:01 PM | #4 |
Perception is King
131
Rep 1,703
Anyone else did any sway bars? seems like there would be more people that installed them.
05-28-2014, 04:25 PM | #5 |
Rep 999
The whole rear subframe for a swaybar??
Performance ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe Looks M colors grill - CF trunk - Sapphire Blue Forgestars F14 |
05-28-2014, 06:47 PM | #6 |
Perception is King
131
Rep 1,703
Im getting solid subs put in and theyll change the Sway bar for free, i wouldnt do it otherwise.
Im also wondering if people change the front sway bars too.
05-28-2014, 07:26 PM | #7 |
Rep 542
Do you like a car that's loose?
If not, skip it...
* '11 E71 X6 M MCB
* '16 Z51 M7 C7 Corvette--SCCA Solo/DE Weapon * '90 Corvette ZR-1 (Fast) |
05-28-2014, 08:26 PM | #8 |
Rep 284
Drives: '13 Melbourne Red E92
Sway bars
I did front and rear. Limited street impact but big gains on track and for autox. LiM3y is spot on - normally the big cost issue is the labor. If they are already going to be back there - GFI.
06-05-2014, 01:43 PM | #10 |
Rep 1,682
Any additional feedback here? I'm hearing mixed reports as to the benefits of a rear sway bar on track for an e90. Yesterday I was told to skip it and instead just dial in spring rates and that many prefer to actually remove them altogether.
06-05-2014, 01:51 PM | #11 |
Rep 5,482
I would not remove unless weight was critical. It's a nice tuning tool to have especially for a quick and dirty rain setup. Soften shocks change pressures and disconnect one end link and you have a nice predictable repeatable rain setup with no spring swapping necessary
But stiffer than stock? Don't see the point and most seem to agree with me unless there is another limiting factor that doesn't allow you to run the springs you want. The adjustability of even the stiffer ones is pretty negligible considering they're not much stiffer in absolute terms and they are attached waaay inboard on the control arm so the impact on wheel rate is small
06-05-2014, 04:14 PM | #12 | |
Rep 633
Richbot, thanks for taking the guesswork out. So far, always words of wisdom. Cheers Lutfy |
06-05-2014, 04:51 PM | #13 |
Rep 5,482
Except for the inboard attachment point part, I was thinking of a different car, these cars are right on the knuckle. So that part was definitely not wisdom, lol
