      05-12-2014, 06:50 PM   #1
Mach1er
Mach1er's Avatar
88
Drives: '13 128i
Lightbulb FYI: Removing Thin Plastidip
When I did my window trim in black plastidip I thought I put on enough coats, but I guess I didn't. It isn't coming off in big chunks and it's worse when its cold.
I'm a little chicken to try plastidip liquifier, Goo-gone, paint thinner, WD-40 because of the damage it could do to the adhesive, rubber seals, etc so I needed a new plan.
I had started just rubbing it with my nails/finger/microfiber to get it to roll but damn is that an arduous process. To get a really clean edge to pull and/or get little stubborn bits off without scratching I decided to use a wooden cuticle tool. Yes, the kind that a nail salon would use. The wood is soft enough to not scratch the chrome trim, but picks up the edge of the plastidip really well.
It still will take me a while to take it all off, but at least there is an end in sight.
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19
      05-12-2014, 09:15 PM   #2
E82135i
Drives: 2011 135i, 6MT
I know you said you are scared to use plastidip liquifier but I did use plastidip dissolver(liquifier) on my rims and it worked perfectly fine. https://www.dipyourcar.com/Dip-Dissolver-Category/
Ask these guys perhaps? They do metion that they don't recommend using it on plastic materials that are black.
      05-12-2014, 09:34 PM   #3
Rob Daman
Drives: 2007 E90 335i
Get goo gone in the hand pump spray. It's not toxic and with a MF it'll come off easier.
      05-12-2014, 10:49 PM   #4
7smurfs
7smurfs's Avatar
Australia
137
Drives: M3 CS
OT: Curious question, how did your rims look after using the dip dissolver?
I hear that plastidip can affect the oem paint which is prevented me from plasti dipping mine...
      05-13-2014, 09:19 AM   #5
E82135i
No problem on mine. I had to re-plastidip due to low threads on tire. I removed most of plastidip by hand and used dissolver to get rid of spots that I missed just to be sure :P
But I did not see any problem on mine... I don't know why they would hurt the paint? just do it LOL
      05-13-2014, 10:07 AM   #6
Mach1er
Mach1er's Avatar
88
Drives: '13 128i
This is window trim, which I'm pretty sure is plastic and is adhered, not just clipped to the car. My worry is that dip dissolver may dissolve the plastic trim/adhesive.
Also, I don't want to re-wax my door panels after doing it, since I just spent 6 hours doing that on Sunday...
      05-13-2014, 10:10 AM   #7
E82135i
Do you have shadowline trim? If not, I think you will be fine using the dissolver. Dipyoucar says that it should be avoid using it on BLACK plastic and does not metion about any other plastic or color. However, you should still call dipyoucar and ask They are really easy to work with.
      05-13-2014, 11:35 AM   #8
LW50
LW50's Avatar
50
Drives: 2021 BMW M3 Competition
Spray on some more, no need to worry about it being sloppy, once it dries peel it all off.
After damaging mine with an ice scraper last winter I removed all of it in less than 5 mins.
      05-13-2014, 12:47 PM   #9
Mach1er
Mach1er's Avatar
88
Drives: '13 128i
Even though the current stuff has been on there for a year? Will it really still stick to itself that well?
      05-16-2014, 01:29 PM   #10
Mach1er
Mach1er's Avatar
88
Drives: '13 128i
Update: Tried the Goo Gone spray gel. Saturate a paper towel, wipe a coat on the plastidip, let sit for a minute, rub off. Comes off really easily! Thanks!
      05-16-2014, 02:46 PM   #11
Rob Daman
Glad it worked out. I spoke from personal experience on that and I did a whole bumper.
1addicts
