05-22-2014, 04:42 PM | #1 |
Rep 47
Brake Bedding and Break In
Can anyone share recommended practices for bedding the brakes on this car? Users manual isn't very specific. I did not order CCBs
05-22-2014, 10:26 PM | #2 | |
Commander-In-Chief
2194
Rep 8,944
Drives: 2023 M2 Coupe, 2020 GLE 450
Brake pad bedding
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
06-23-2014, 07:41 AM | #4 |
Rep 570
Factory Pads
After a lot of research and a few experiments of my own, I'd follow the factory recommendations on brake wear-in. Basically, the factory pads wear in, over time, after some general heating and use on the street. Bedding factory pads on cast iron rotors, following recommendations for aftermarket performance or race pads, will overheat and glaze the factory pads, in my experience.
On my E90, I currently run factory pads on the street and Pagid race pads on the track. I bed the Pagids just prior to each track day. Due to the size of the rotors and mass of the system, they need a fair amount of work/braking to get heat into the brakes (for bedding). I bedded the factory pads and they glazed, even when I tried not to overheat them. The next set, I just wore-in w/normal driving. They have awesome bite and absolutely no issues. Lesson-learned from my side. I am sure others have had similar or different experiences. My $.02 anyway. -Brian PS The cast iron/compound rotor brakes from the M4 will be similar to the E9X in this regard. However, we'll see how the fixed caliper and multiple pistons improve things. I'd imagine bedding won't be too much different. |
06-24-2014, 08:26 AM | #5 | |
Rep 655
