      06-18-2014, 02:41 AM   #1
missapei
Drives: 135i
Need Help ,Car shuddering at idel?
Hi all
got an N55 135i, FBO stage 2 PTF
car was runing fine for 4 monthes after all the aftermarket parts
recently i feel like my car shuddering a lot when come to a red light.i mean you can strongly feel the shake at steering wheel .
most happen at low rmp, got it checked , said it might be the Vanos unit thats been recalled?
or what do you think? anyone in similar situation?
oh, there is once i didnt warm up the car and floor it, then engine light came on, says reduce the power or whatever, but i clear the code and restarted the car, it gone
and didnt happen again until couple weeks later i was reving up to around 3.5 to 4k to warm up the car, and the engine light came in again.
would this be damaging something inside the engine that caused shuddering ?
      06-18-2014, 06:57 AM   #2
JinAM
Drives: 335i
Should leave the fault there and get the fault code read out to identify the cause of it.
      06-18-2014, 11:00 AM   #3
missapei
Drives: 135i
i know, but now it still shuddering at lights, engine light didn't came on again
      06-18-2014, 06:19 PM   #4
UR25IO
UR25IO's Avatar
Australia
97
Drives: 2011 BMW 135i M-SPORT DCT
My 2011 N55 shutter and serges forwards when coming to a hult at a set of nights every now and then. It has been happening around 2 years now, no one seems to be able to resolve it. So im thinking its normal for N55 as I know of.
Reving up to 3.5 - 4k that is fairly high- correct me if im wrong... That is like normal driving to me!
When engine light comes on after giving it, does not sound good.
BMW Aust just Started a Recall campaign about 3-4 weeks ago after a month or two when the BMW Germany has announce it to the world. My car was part of the recall group. BMW Aust are still waiting for parts to arrive. You should Check with your dealer to get an early book in.
      06-18-2014, 06:26 PM   #5
drjekl
Drives: E92 335i
How many kays are on the car?
How long ago did you have the DP installed?
How old are your coils/plugs?
      06-19-2014, 08:13 AM   #6
JinAM
Drives: 335i
If the engine light went away by itself without clearing it, the fault would still be stored in the computer.
      06-19-2014, 08:35 AM   #7
missapei
Drives: 135i
23000 km
Dp installed at Feb this year
Coils/plugs haven't been changed I believe
It starts shuddering a lot again today
      06-19-2014, 05:36 PM   #8
drjekl
Drives: E92 335i
Originally Posted by missapei View Post
23000 km
Hmm I would start with some fresh plugs.
I had a similiar issue (rough idle, jerky sensation at low rpms oh and a misfire) changed my plugs and it was much better!
I still had issues, which was rectified with new vanos solenoids and wideband sensors, albeit in your case I would guess these items should still be OK with such limited use so perhaps try plugs first and then if you still have issues get an indy involved?
Does it start fine (no excessive cranking?) and does it cold idle smoothly?
      06-19-2014, 07:54 PM   #9
missapei
Drives: 135i
i got booked in for vanos next week,
And I found car shaking more when it's cold, when it warms up a bit, gets a little better, but still annoying me a lot
      06-19-2014, 08:05 PM   #10
7smurfs
7smurfs's Avatar
Australia
137
Drives: M3 CS
As Jin has already said, you will need to check the codes to get an more definitive answer i.e. misfire on which cyclinder, fuel pump, VANOs etc
Misfire codes can be a bit trickier... I've currently got one on high RPM and active motorwerkes changed the coil with no result. Going back to try to sparks this time around!
      06-20-2014, 03:04 AM   #11
missapei
Drives: 135i
sigh, thanks guys
1addicts
